Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
fuel leak
Old 02-10-2016, 07:05 PM
Dagon's Avatar
Cool fuel leak
my 1994 f150 has 2 gas tanks rear one leaked so i stopped using it front tank began to leak also,changed front tank now somehow fuel is getting to the rear tank and leaking when i park on a slight incline any ideas?
Old 02-11-2016, 11:06 AM
Alanah_Rae's Avatar
Ford had a recall on that problem. Can't remember if your truck was affected. They put an anti-return valve on the supply line of the fuel pump. Best bet is that the
front fuel pump front fuel pump
is bad. The switch valve just turns on one pump or the other. There is nothing between, unless the pump is faulty.
Old 02-12-2016, 05:28 AM
Dagon's Avatar
thanks i will look into that
Old 02-12-2016, 11:00 AM
Shay_Fox's Avatar
Update us when you resolve your problem mate.!!
Old 02-12-2016, 11:08 AM
Maybe this will help,
Generally when drawing from one tank causes the return fuel to go to the other tank , the problem is with the tank that is overfilling and in this case as just about everyone here gathered The problem is with the overfilling tank fuel pump, Check valve !
Old 02-15-2016, 12:17 PM
Alanah_Rae's Avatar
Great lines. Its really helpful. thanks for sharing.
Old 02-17-2016, 05:28 AM
Dagon's Avatar
thanks for all the info i never would have thought fuel pump when i changed the front tank i reused the old pump guess i should have just gone with a new one not looking forward to having to drop the tank again
Old 02-17-2016, 05:31 AM
Dagon's Avatar
i will dig around see if i can find any recall notice,if there was i never got it,have had the truck since new
Old 02-17-2016, 10:23 AM
LakelandFordParts's Avatar
Former Sponsor
If you send me the VIN or post it I can look into the recall for you.
Old 02-17-2016, 01:51 PM
I'm not sure which fuel pump you reused. Presently , if you are getting fuel placed back in the rear tank when using the truck on the front tank, that fuel pump in the rear tank is defective.
Quick Reply: fuel leak
