Central MT, WY, CO, ND, SD, NE, KS
Hydraulic squeal in brades
Old 06-11-2012, 02:49 PM
TJP746's Avatar
Default Hydraulic squeal in brakes
I have an 08 F-350 DWD -6.4 with 20 K.
Sat all winter in heated building and since spring has developed a very noticable sqeal - sounds like hydraulic pump starved for fluid - quits when I step on brakes.
Checked fluids - OK. Any Ideas before I take it in.
Thanks
Tom
Old 06-11-2012, 05:01 PM
bluewind's Avatar
Check the drive belts. They may have dried up a little bit and slip under power. It is not that likely but possible.
Then check the calipers. Make sure they float as designed. You should be able to slide them easily in and out. If needed clean and slightly lube the sliders or pins.
Old 06-11-2012, 06:45 PM
Have you had a chance to check all brake pads for wear?
Old 06-12-2012, 06:30 AM
TJP746's Avatar
Thanks guys will check out your ideas and let you know!
Tom
diyj98
11-11-2008 12:25 PM
jjcast13
10-10-2008 10:18 PM
mhaggitt
02-13-2007 01:53 AM
TXRDSTAR
06-15-2006 03:31 PM
jrqf
11-07-2005 04:32 AM
Quick Reply: Hydraulic squeal in brades
