About how much should a paint job cost - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 09-18-2011, 08:48 PM
Default About how much should a paint job cost
for a 2003 Crown Victoria? I know it differs because of many factors but in general what is a good price range for a paint job. Car is black.
Old 04-01-2014, 09:24 PM
Going back Black, with virtually no repairs/rust, in base coat, clear coat, should start around 2 grand. Much cheaper and I'd be suspect of cheap paints, etc. You can save some doing sanding, etc yourself.
Old 08-25-2016, 08:42 AM
Hello
I've been doing a lot of research on auto painting the last week or so
I painted my wagon about 3 years ago, and rust is already showing through.
that is what you get by not doing homework and listening to the guy behind
the counter
He sold me on a primer surfacer, what a mistake, plus It's a base\clearcoat
so it all has to come off... and don't let anyone tell you other wise... base paint
never hardens. it's the clear that hardens.
Now just material cost in today world is (Ouch) got me.
Sherwin Williams Dimensions paint is about $400 a gal for single stage. plus or minus
Their epoxy primer DTM is about $230 a gal. those price are just for
that, there is extra for the hardener and reducers.
so you can be up to $$700 to $1000 in just material depending on how much
you need, and these prices are for solid color, metallic in single stage are higher
I paid $90 for a quart with hardener for single stage metallic from SW
and that was from a distributor, the actual SW store wants way more $$$$
Since you have a Merc, with a base\clear, you need to strip the paint down to bare
metal... do research on this, like I said base paint never hardens.
There is a product from Rust oleum that is a base\clear coat remover , that is
probably the best way to go, as your sandpaper will clog all the time
So that 2k price sounds about right.
I'll not be using SW paint, even though it very good, just out of my money wheel
but there are many other good quality paints out there, so do the research
BTW if your looking at having one of the chain paint shops, Macco ask them
which paint they use, I know before they sold 1 day was using Sherwin Williams
Epoxy primer is water proof, and air proof... so once the metal is prepped right
it will not rust through. and if you panels are straight then that's all you need
but if body work is needed, then strip paint, epoxy, body work, epoxy over worked
area, then if needed a surfacer primer is needed which is sand able
Well guess I shot my mouth off enough..
Best
Thread Thread Starter Forum Replies Last Post
BMW 325 E30 paint job RIXCAR Off Topic 1 12-18-2015 01:29 PM
New Early Bronco Paint Job... In Mud Brown Bullitt94 Off Road 1 01-08-2015 04:33 PM
Brand new car getting paint job... r3ap3r911 New Member Area 2 10-10-2012 05:56 PM
How much does Sync cost after... catz12 General Tech 0 02-07-2010 11:01 PM
what color should I paint it 16andrebuildinan84 Ford F-250 & Ford F-350 0 05-06-2007 04:41 PM
Tags
car, company, cost, crown, ford, job, motor, paint, paintjob, powered, price, share, vbulletin, vic, victoria
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
