Engine & Internal Lounge Chat about beefing up your insides here.
Distributor Shaft Siezing Up
Old 01-28-2005, 04:08 PM
jrocco's Avatar
Default Distributor Shaft Siezing Up
About a year ago, my 351W stopped running. I ended up pulling the distributor and found that the gear pin had sheared. I also found that the shaft was extremely hard to turn. I disassembled the distributor and found that the oil grooves on the shaft were gummed up and the shaft was nearly siezed in the bushing. I cleaned out the grooves, used emry cloth to clean up the shaft and reinstalled everything.
Yesterday I had to pull the distributor to install a new Intake Manifold, and noticed that the Distributor was not moving freely. I disassembled it and found the same problem.
This is a completely rebuilt motor with lots of performance parts (about 12,000 miles now) and I use Valvoline 10W30 motor oil. There is no evidence of any gumming in the lifter valley or under the valve covers. These areas look extremely clean.
Has anybody seen the is type of problem before?
jbrote47
01-27-2006 12:52 AM
fordmann67
12-21-2005 04:02 PM
cwbronc
07-12-2005 07:17 PM
blue_streak
04-08-2005 03:24 PM
jfhattsr
10-21-2004 05:46 PM
Quick Reply: Distributor Shaft Siezing Up
