Engine & Internal Lounge Chat about beefing up your insides here.
Timing chain cover corrosion
Old 05-21-2014, 06:02 PM
junkyardjeff's Avatar
Default Timing chain cover corrosion
My 88 5.0 developed a coolant leak between the block and water pump and looks to be coming out of the cover,anybody know if they can corrode enough to leak out of the coolant passage. If it was not for the serpentine belt alt bracket I could have seen where it was leaking while running so I will now have to wait for the motor to cool down to put the coolant back in so I can pressure test.
Old 05-21-2014, 09:17 PM
It was a gasket failure and glad it did not leak into the motor,the po replaced the timing chain and water pump but did not tighten the bolts enough.
Old 05-21-2014, 10:05 PM
Thumbs up
Glad it was the easier fix
obieone1
05-20-2013 12:28 PM
NickTurbo
04-01-2012 09:21 AM
B5in
10-25-2011 10:04 PM
1life
12-03-2008 05:47 PM
Dennis Moore
10-26-2005 06:04 PM
Quick Reply: Timing chain cover corrosion
