144 ci starts and runs as long as starter is engaged
Old 06-05-2008, 03:36 PM
deano1960falcon's Avatar
Default 144 ci starts and runs as long as starter is engaged
Can anyone help me out? I have a 1960 falcon with a 144ci. When I try to start the car the engine starts and runs untill I let off the key. I have also have turned the key to run and the jumped the solinod and it does the same thing. I do have power to the coil and the points when the key is in the run position. Any suggestions?
Thanks
Jeremy
Old 06-06-2008, 01:00 PM
goinstrong's Avatar
Default RE: 144 ci starts and runs as long as starter is engaged
Is there power to the coilAFTER you turn the key to start and return it to run? Try turning up the carburetor idle screw a touch maybe.
Old 12-17-2008, 12:37 AM
goinstrong's Avatar
A new solenoid might help too.
goatsauce
04-15-2013 08:32 PM
tahafisaka6
02-14-2011 10:59 PM
skid2964
09-27-2009 02:29 PM
daveranger
06-27-2007 08:00 PM
Quick Reply: 144 ci starts and runs as long as starter is engaged
