Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Help 84 Bronco II XLT
Old 04-13-2016, 03:18 PM
Wraithman83's Avatar
Exclamation Help 84 Bronco II XLT
I have a problem locating the right water outlet valve (which has cracked). All parts found do not fit and are different then the original. I have tried junk yards and online searches with no help. I did find one at a junk yard but it also cracked. Do I need to change out something entirely or is this just an elusive part?
Also are all 1980s Rangers and Bronco II spark plugs gapped the same?
Old 04-13-2016, 11:57 PM
Welcome to the site..
Can you post a image or two ?
Old 04-20-2016, 10:24 PM
don't know if I attached the images correctly...please let me know this is old software.
Attached Thumbnails Help 84 Bronco II XLT-20160418_192056.jpg   Help 84 Bronco II XLT-20160418_192119.jpg   Help 84 Bronco II XLT-20160418_192137.jpg
Old 04-20-2016, 10:34 PM
replied with photos love your HD ford
Old 04-21-2016, 10:51 AM
Have tried LMC Truck? their images aren't representative or your water outlet, but I'd bet they've run into it before.
You could use a Mustang II outlet, and add in a fitting for the coolant bypass. The cast iron units are more workable should you need to resize/tap the ports. Hoses may need to be sourced if the angle/length changes..
Old 04-21-2016, 10:56 AM
Mustang II waster outlet..
capt_bley
03-15-2010 09:12 PM
noonrock
01-13-2009 09:00 AM
W_N_Sluss
03-15-2007 05:29 PM
JShin415
10-06-2006 10:05 AM
lespauljr2005
09-27-2006 08:19 PM
Quick Reply: Help 84 Bronco II XLT
