Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Wiring issues
Old 12-09-2015, 11:53 AM
80 bronco's Avatar
Default Wiring issues
Hey folks I have a 1980 bronco that I'm having some problems with the wiring in it needs some work done but only problem is when I tried to look at the wiring diagram for 1980 the fuse box is different just wondering if anyone knows where I can look up the fuse box # and find out the year it's out of the # is EOTB-14AO68-AA thanks
Old 12-09-2015, 02:12 PM
Can we ask what kind of wiring work you plan to do?
The reason I ask is, depending on what you plan to do , there could maybe be an easier way to accomplish your plan(s) than getting involved with the fuse panel. The panel is not that complicated, but the age may come with unseen problems.
Old 12-30-2015, 10:18 AM
LakelandFordParts's Avatar
Former Sponsor
I was able to get a Ford service part number using a slightly different form of the number you have. I used E0TB-14A068-AA and it crossed over to EOTZ-14A068-A which is the part number that Ford dealers will use. It looks like that is unfortunately obsolete and diagrams are nonexistent. You may want to look into something like this: 1980 Ford Bronco Wiring Diagram Manual Set | eBay
tdkruse
04-07-2016 01:22 PM
Jean Ingram
07-12-2015 07:12 AM
dwarber
11-04-2009 12:12 PM
mic
07-04-2007 08:01 PM
ohlalasibon
02-02-2005 10:38 PM
Quick Reply: Wiring issues
