Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
1996 ford contour brake lights
Old 04-06-2009, 05:19 PM
svargas0304's Avatar
Default 1996 ford contour brake lights
My 96 contours brake lights will not come on ,changed the bulbs and checked the fuses but still not working ran out of ideas need help thanks
Old 12-30-2010, 04:24 PM
bodmd98's Avatar
Check the 4 pin connector in the steering column for the turn signal switch. The central power feel terminal (female) provides power to the brake light circuit. The female multipin connector is no longer available from Ford. In order to replace, find a multipin connector with similar connector spacing and trim the outer body to fit into the recess on back of the turn signal switch.
willy j
09-30-2013 07:42 PM
svargas0304
04-08-2009 04:53 PM
moonunitpurple
03-08-2007 09:51 AM
Quick Reply: 1996 ford contour brake lights
