Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
1998 Contour, where is the VSS?
Old 08-05-2007, 11:38 AM
Fredo's Avatar
Default 1998 Contour, where is the VSS?
I have a 1998 Contour 2.0L with an automatic. Where is the Vehicle Speed Sensor ? My speedometer is working on and off intemittently. Thought I would start with the VSS.
Old 08-05-2007, 12:38 PM
Default RE: 1998 Contour, where is the VSS?
Manual shows it to be trans mounted.. Electrical/engine....
[IMG]local://upfiles/6756/A78ECE4B60B7445F89B6DB28BC828040.jpg[/IMG]
[IMG]local://upfiles/6756/BBD353463A21495E83659C5028EB7B6F.jpg[/IMG]
Old 08-11-2007, 01:48 PM
Fredo's Avatar
Found the VSS and replaced it with a new one, but I still have the same problem. My speedo works intermittent. Sometimes it will drop down to 0 and stay there, sometimes it will peg out at 130mph andstay there. Sometimes it works normally. Anyone have any ideas?
Old 12-30-2010, 06:23 PM
bodmd98's Avatar
Start diagnosis of speedo problems by checking if the cruise control is working even with erratic or non function of the speedo. If cruise works then your sensors are okay. Most likely replace cluster. Sometimes plugging and unplugging the multipin connectors on the back of the cluster will give you speedo and other gauge functions again. Check for replacement from salvage yards as first choice.
Downtown
12-21-2015 08:57 PM
dmoore1965
11-10-2009 12:40 PM
dluper
09-29-2009 11:34 AM
smittyd
01-08-2009 08:45 AM
02grand
03-19-2008 01:49 PM
Quick Reply: 1998 Contour, where is the VSS?
