Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Cannister purge issue, surging
Old 05-08-2015, 01:36 PM
LADave's Avatar
Default Cannister purge issue, surging
After I park my '98 Contour with Zetec 2.0 4 facing downhill, I get surging at all speeds, including idle where it's most noticeable. The engine will speed up maybe a few hundred rpm for about five seconds, then slow down for about the same amount of time, and repeat.
I'm thinking gravity might be pushing fuel through the lines and loading up the charcoal canister, then the on/off speedup is a purging process. This can't be entirely normal, so how do I fix it?
Old 05-08-2015, 02:55 PM
When you put fuel in the tank do you try to get as much in as you can ? If so , canister may be overloaded with fuel. Stop putting fuel in when the nozzle first shuts off if this is what is happening.
Sue Ouderkirk
05-18-2015 03:30 PM
Aquakittie
01-27-2012 02:16 PM
JimMaher
05-06-2009 07:03 AM
bbensten
12-05-2006 01:28 PM
Quick Reply: Cannister purge issue, surging
