Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Question about replacing a dip stick tube
Old 04-24-2008, 01:18 PM
jingdejun's Avatar
Default Question about replacing a dip stick tube
Hello,
The engin oil dip stick of my 1998 Ford Countour break, with the rod part remaining inside the tube. I guess I have to uninstall the tube and remove the broken stick.
My question is how to uninstall the dip stick tube. Do I need to discharge the engin oil first? If not, when I pull out the tube upward (after I removing some fixztion bolts if there are some), will the engin spill all around?
Thanks for your advice.
-Derek
Old 04-24-2008, 04:59 PM
Default RE: Question about replacing a dip stick tube
The same happened to my Contour'98 during the last change-oil operation... but the guys at the shop managed to remove the broken part and replaced it with an equivalent... no tube unmount or emptying of the oil, as far as I know. I even was able to drive the car for one day until they got the spare.
DR
Houston TX
Old 08-21-2008, 03:30 AM
dannydoo's Avatar
theres 1 bolt that holds it in then yank it out.You dont have to empty oil.
work-farm
08-08-2014 08:38 PM
bow-n-head
06-18-2014 02:00 PM
cwowolf
12-28-2008 10:44 AM
philspin
05-06-2008 09:04 PM
Im4dhskrs
01-03-2006 04:25 AM
Quick Reply: Question about replacing a dip stick tube
