Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Replacng timing belt on 1998 2.0l vct engin
Old 09-22-2007, 11:55 AM
bacl2000's Avatar
Default Replacng timing belt on 1998 2.0l vct engin
OK, This has been a monster. First the car oveheated and warped the head. Head has been resurfaced and pressure tested.. Reinstalled and having problems getting the timing to lock in. Used alignment tool on the cams and got the timing belt back on. rotated the crank two revolutions and the exhaust cam is not ligning up. At first I just loosen the bolt and move the cam and that seem to keep it aligned. it would try to start but would not . Then I read a tsb 89-9-8 that detailed aligning the the VCT to the cam at the TDC position. Will I have done that but now I am at the same issues. It is not ligning up. If I loosen the bolt this time am I not loosing the alignment I did by theTSB or do I need to remove the belt and move the spocketuntil I get the alignment correctly.
Old 08-01-2010, 09:17 PM
robertg927's Avatar
Default My 2000 2.0 L vct has the same problem
This is a really old post, and I see you didn't get any help from this forum, but did you ever get the problem solved? If so, what did you have to do?
Robert
Chad Flowers
04-19-2012 11:41 PM
94svt
08-10-2010 08:39 PM
FIRE RANGER
12-06-2009 01:17 PM
Qaiphyx
04-04-2008 11:59 AM
tinman
03-23-2007 10:09 PM
Quick Reply: Replacng timing belt on 1998 2.0l vct engin
