1985 radiator fluid level
Old 02-10-2016, 12:44 PM
ba_50's Avatar
Default 1985 radiator fluid level
This Ford LTD mid-sized wagon with a V6 seems to run about two inches below cold add line in reservoir and stays just below the outlet tube in the radiator. If I fill it to the add line it is down again in a couple of days. There aren't any leaks showing on the concrete when parked. It had a new radiator put in about 5 years ago. It hasn't ever gotten hot even in Florida but it still makes me wonder. Thanks.
Old 02-10-2016, 01:29 PM
You can probably rent a radiator pressure tester from an auto supply store .After you fill the radiator to the top , connect the pressure pump/tester to the radiator and pump it up to no more that 15 pounds pressure and see what the gauge does. If it starts to lose pressure , look for external leaks, water pump , hoses, etc. If it does not lose any pressure check the coolant recovery bottle for possible leak.
Old 02-11-2016, 10:32 AM
ba_50's Avatar
Got under the car and found some green fluid mostly on the bottom pulley and some horizontal tubes. Didn't see any hose leaks though.
Old 02-16-2016, 10:27 AM
LakelandFordParts's Avatar
Former Sponsor
Could be the water pump. I would follow hankys suggestion and run a pressure test because that will find the problem for sure.
Old 02-16-2016, 11:16 AM
ba_50's Avatar
I plan on having the whole thing checked over anyhow. Sounds like a good idea.
It sounds like something sounds and feels rough especially when first starting in the morning.
Old 02-27-2016, 09:57 AM
ba_50's Avatar
I took it to a mechanic and he said it needed a water pump but he didn't pressure test it. He said that 2 long bolts might break off. Anyone know what the chances of that is? Thanks
Old 02-29-2016, 01:46 PM
Former Sponsor
If they are ceased it could happen, I would suggest using some penetrating oil to aid in the removal of the bolts.
Old 03-07-2016, 11:35 AM
ba_50's Avatar
Is a propane torch hot enough?
Old 03-10-2016, 03:55 PM
Former Sponsor
I think that may cause some more unwanted issues.
MatlockPaul
02-12-2014 02:44 PM
makuloco2000
11-11-2013 09:30 PM
lostinnspace
04-03-2011 05:23 AM
Kyle_1724
12-21-2007 07:59 PM
factory310
04-28-2007 06:23 PM
Quick Reply: 1985 radiator fluid level
