97 Crown Vic / no turn,hazard,brake lites
Old 04-01-2008, 04:18 PM
patrickcharles's Avatar
Default 97 Crown Vic / no turn,hazard,brake lites
I have a 97 crown vic, turn signals out, hazards out, brake lights out.
BRAKE warning lite on dash is on. Headlights work, wipers work.
Is it the multifunction switch or light control module?
Old 04-01-2008, 07:18 PM
way2old's Avatar
Default RE: 97 Crown Vic / no turn,hazard,brake lites
Check the stop light switch on the brake pedal first. Then the Multi-function(turn signal)switch. The lighting control module is not the problem.
Old 04-01-2008, 09:32 PM
what would the brake switch have to do with hazards and turn sigs?
Replaced Multi function with no luck.
Any help would be appreciated!!!!!!
Old 04-02-2008, 07:35 PM
way2old's Avatar
Your brake lights and turn signal bulbs are the same circuit. The multi function directs current to the solid brake light, or the flashing signals.
Old 04-02-2008, 09:45 PM
Makes sense, will try, but running lights are on not bright brakes. Thank You...
Old 07-09-2008, 03:44 PM
I had a similar problem and was told to spray some WD40 into the hazard light switch on top of steering colum and work it in and out a few times. Did just that and the problem disappeared.
Old 11-10-2008, 09:01 PM
Thank you very much for your post! I was able to use your solution and save myself at least 60$, the price of a new multi-function switch. My first instinct was the lighting control module which costs much more than the switch. Now I'm trying to figure out what kind of new tool to buy with the money I saved!
Glowbug
01-28-2022 12:43 PM
Durr
10-08-2011 09:02 PM
CADOP
01-01-2011 05:58 PM
demonking75
11-17-2008 09:58 PM
patrickcharles
04-01-2008 04:34 PM
Quick Reply: 97 Crown Vic / no turn,hazard,brake lites
