'99 Crown Vic fuel tank slow fill
Old 09-28-2016, 06:07 PM
kerley's Avatar
Default '99 Crown Vic fuel tank slow fill
Our '99 Crown Vic, I am having a problem fueling the CV, It takes forever to fill the gas tank, I have to pump very slow or it spits gasoline back at me. Does anyone know what the fix would be?
Thank you. Tom
Old 09-28-2016, 07:50 PM
A clogged or closed vent valve in the fuel evap system can cause this type problem. Engine off, the vent valve is usually open to allow pressure created when filling the tank with fuel to go out through the charcoal canister ,through the vent valve to the atmosphere. Sometimes the vent valve exit gets clogged with dirt due to it's location and makes for difficult filling of fuel into the tank. The valve is located usually under the vehicle and it should be normally open. It is supposed to close when the engine is running.
Jon.H
09-16-2014 11:16 AM
bernieb
09-30-2010 08:36 PM
kyle87
09-24-2010 03:33 PM
poconopat
09-23-2010 11:49 AM
genius2
03-21-2008 11:05 AM
Quick Reply: '99 Crown Vic fuel tank slow fill
