Power Steering Fluid
Old 10-16-2014, 04:30 AM
Lawrence Henderson's Avatar
Default Power Steering Fluid
Just changed out the power steering pump and need to put power steering fluid in. the problem is, I cannot find what fluid I should put in. it is a 1995 Ford Crown Victoria.
What kind or brand of power steering fluid do I put back in?
thank you!
Old 10-16-2014, 04:45 AM
Use Common Sense's Avatar
Plain Ole' ATF. Mercon V will work and is backwards compatible for Mercon requirements.
Old 10-16-2014, 04:49 AM
John Renold's Avatar
You can use Mercon or Dexron III ATF, Type F ATF or regular power steering fluid these three have same hydraulic properties when used in a power steering system.So, you can use these power steering fluid.
Old 10-16-2014, 09:10 AM
thank you for your replies.
would you recommend one above another?
Old 10-16-2014, 09:47 AM
I keep getting myself mixed up, too, but those fluids you listed are transmission fluids . . . I was looking for any particular power steering fluids . . . thanks for you help anyway.
Old 10-17-2014, 03:15 AM
The fluids listed are hydraulic fluids that happen to be used in transmissions and power steering units. If you want a red colored power steering fluid use one of the listed ATF fluids and if you want a clear fluid use the higher priced "Power Steering" fluid.
Jonathanes91
02-08-2008 07:42 AM
DARIN J
08-10-2007 12:22 PM
daveranger
04-20-2007 10:49 AM
VegasBob
11-10-2006 02:39 PM
tennesseesaturn
11-08-2006 11:55 PM
Quick Reply: Power Steering Fluid
