1985 E350 brake and glow plug issues
Old 07-26-2011, 06:00 PM
becksbikes415's Avatar
Default 1985 E350 brake and glow plug issues
New here, thanks for your patience and advice. Working on a 1985 6.9L e350 diesel and here's my issues:
Glow plug controller or glow plug went out-tried starting it up and the glow plug indicator light fails to come up, so I bypass the controller to the relay which solves the problem when installing an on/off switch. Complicated emergency fix because it was parked on the street in SF and we didnt wan't to get towed.
other issue is the brakes, was driving down the highway and lost pressure to the brakes, brake light indicator came on, burning rubber smell was present. Not sure where the master cylinder is at, does this mean there is air in the lines and ill have to bleed the system?
any advice or procedural advice would be so helpful-thanks!
Old 07-27-2011, 07:24 PM
From the question you asked regarding the master cyl, i hope i'm wrong, but you would be better served to have the brake work done by someone who is more experienced with brake systems.
makuloco2000
01-19-2014 10:23 PM
indigoshaman
10-14-2012 06:13 PM
indigoshaman
01-29-2011 10:03 PM
Tater50
03-29-2008 07:51 PM
blixx003
09-10-2005 07:33 PM
Quick Reply: 1985 E350 brake and glow plug issues
