1985 E 150 with dash light issue
As stated, I'm having issues with dash lights. I just got the truck and find that I either have no light, half light, or complete light on the dash. I also find that the left turn signal works, but the lighted arrow doesn't. Is there a replacement bulb for the signal? Does the dash panel come out, or is it a crawl under the dash job? Any idea what is causing the intermittent dash lighting? Thanks.
Some you were able to change the #194 bulbs without pulling the dash away and others it was easier to remove a few screws pull the dash back and replace the bulbs that way.
There was a spring clip that you could depress and remove the speedo cable. That made it easier to get to the bulbs. If they have never been touched since 1985 , it's a good bet most of the bulbs are burned out . They will have a black appearance when removed and that's how you can tell definitely that they are burned out.
Simple job and you get immediate results when you install the new bulbs.
aangel
01-16-2009 03:01 PM
