1987 Econoline won't stay running
Old 07-30-2006, 02:24 PM
cruzandkathy's Avatar
Default 1987 Econoline won't stay running
Hi..we bought a 1987 Econoline 150 with 5.0 302. Van ran fine..then started chugging really bad..now won't stay running at all. Turns over then dies... took off the catalic converters, unhooked the erg valve and did a complete tune up. As you can probably tell I am a lady that doesn't know much about cars..my hubby is doing the work..I do know that it has an fuel injector in it. Hubby does work on VW's, but never a van like this..it has him stumped..and help would be appreciated...thanks, Kathy
Old 07-30-2006, 03:17 PM
Default RE: 1987 Econoline won't stay running
Is the engine getting gas or spark????????
Old 07-30-2006, 03:28 PM
Yes its getting gas and spark. Unhooked gas line all the way up to the fuel injection and turned it over and its shooting gas and the spark..its getting spark or it wouldn't be firing.
Old 07-30-2006, 03:38 PM
If it's getting gas and spark it should run.When the engine dies out recheck it for gas and spark .It is most likely dying out from not enough fuel pressure or spark.
Old 07-30-2006, 03:42 PM
Hubby was wondering if it might be the computer..keeping it from running
Old 07-30-2006, 03:49 PM
It might .The computer control's fuel injection,timing,spark and more. When it run's does the check engine light come on?
Old 07-30-2006, 03:52 PM
No the check engine light does not come on ..but hubby says he doesn't even know if its hooked up. was wondering if it could be electronic modular. Hope its not the computer
Old 07-30-2006, 04:00 PM
Make shure the firing order is correct. Check all vacuum lines are connected. Check all wire's and make shure the egr vaulve is connected.
Old 07-30-2006, 04:04 PM
Hubby says he has already don't all of that..thus the feeling of frustration..LOL..Thanks for your help though...if you think of anything else please let us know
jkkay
02-24-2021 03:39 PM
rgray32
10-16-2007 03:57 PM
kennylogel
04-06-2007 07:44 PM
rmcard
12-17-2006 06:30 PM
chaumer
02-20-2006 03:37 AM
Quick Reply: 1987 Econoline won't stay running
