AC fuse location 2000 E-350
Old 04-24-2009, 02:26 PM
racerdave83's Avatar
Default AC fuse location 2000 E-350
My AC compressor isn't turning. Where is the fuse located? Fuse number? My owner manual doesn't even mention a fuse for the AC. And is there a relay for the compressor too? Where is it located? Thanks.
Old 04-24-2009, 03:00 PM
Welcome to the site..
Have a 12V test light?
If so, it's easier to first check for system voltage/power distribution to the low pressure cycling switch on the Violet wire.. Then, if the system has a sufficient charge it will have 12v out/through the switch on the Red/Yellow wire.. The cycling switch is located out on the accumulator/drier, looks like a round tall cylinder mounted near the evaporator case with the A/C hose coming off the top.. Relay and fuse positions are in your owners guide, but I can post them here if you don't have one..
Old 04-24-2009, 04:06 PM
Thanks Hayapower, I'll try the pressure switch, but please post the fuse and relay information.
Old 04-24-2009, 05:19 PM
I jumped the pressure switch and the compressor started turning, so I must be low on freon. Thanks for your help!
jeffreyedgar
04-09-2018 08:18 PM
Freewalker
05-19-2012 09:58 AM
zeke nolan
02-27-2011 02:50 PM
93f250xlt4x4
06-30-2008 11:16 PM
richg9781
05-08-2007 07:55 PM
Quick Reply: AC fuse location 2000 E-350
