1998 e150 sway bar bushing removal
Old 03-16-2007, 08:03 PM
bread320i's Avatar
Default 1998 e150 sway bar bushing removal
The bar is off the van and I cant get the bushings to come out of thefront axle.
Is there a recommended tool to remove them?
Thanks, Adam
Old 03-17-2007, 01:18 AM
goinstrong's Avatar
Default RE: 1998 e150 sway bar bushing removal
If the bar is off and they're not bolted-on or riveted-on types (and not being reused) then a screwdriver or little pry bar and pliers should pull it out. Use the screwdriver to loosen the rubber from around the edges. Then grab a piece and pull. This will not work if it's bolted or riveted THROUGH the rubber.
Old 03-17-2007, 03:01 AM
Here's what the remove/install tool looks like.. Should be able to improvise..
[IMG]local://upfiles/6756/BA3C097F1CE54D789F2AE6592083024F.gif[/IMG]
[IMG]local://upfiles/6756/5169F1F137914C2A9BD34D124953E43D.gif[/IMG]
danddia
06-28-2008 03:16 PM
lostneedhelp
02-12-2008 02:01 PM
Davetheslave
07-17-2007 04:05 PM
davej
10-19-2006 01:04 AM
91EXPLORER
07-24-2006 11:35 PM
Quick Reply: 1998 e150 sway bar bushing removal
