2001 E150 ball joint & tie rod replacement
Old 08-28-2015, 01:40 PM
Polly's Avatar
Default 2001 E150 ball joint & tie rod replacement
I am looking to upgrade my ball joints (at the steering knuckle) and tie-rod ends. So far I have purchased new Moog components for this. From the homework I have done it looks like the camber/caster bushing needs to be removed to replace the upper balljoint, but I'm not sure if the bushings should also by replaced while everything is apart, so I would like some feedback on that. Also any other words of advice; other tools needed; would be appreciated.
* I'm planning to rent a ball joint press kit from a local parts store.
* I'm planning to get an alignment when the work is done.
Old 08-30-2015, 04:18 PM
Mark the position of everything before taking it all apart. You will probably reinstall the bushings in the same position on assembly. I believe you are talking about the alignment bushings at the upper joint.
prestigeplumb.661
02-15-2020 10:29 PM
mexiburger
08-08-2006 10:43 AM
gopher
04-23-2006 01:17 PM
Bigg_billy
09-11-2005 12:24 AM
DYI
03-28-2005 11:54 PM
Quick Reply: 2001 E150 ball joint & tie rod replacement
