Ignition key tumbler problem
Old 04-11-2007, 07:20 PM
damonlathe's Avatar
Default Ignition key tumbler problem
I have a 1991 Ford Universal Conversion van...which I think is the same as the Econoline.
At any rate. V8. But I'm having a problem with the ignition key tumbler assembly. I stopped for a few minutes then when I went to start it again the key would not go all the way around to engage the starter....and the shift was not released.
Any ideas on how to remove it? I have another van for parts....just want to swap the parts over.
Old 04-11-2007, 08:11 PM
damonlathe's Avatar
Default RE: Ignition key tumbler problem
Never mind. I figured it out. Its not the tumbler or key cylinder anyways. It looks like its inside the steering column itself....any ideas? Looks like I need to remove the entire steering column?
Hambrock10
07-10-2013 05:11 PM
Rancherodude
02-09-2008 02:14 PM
Pastor Wells
07-11-2007 08:46 AM
Pastor Wells
06-30-2007 08:21 PM
Quick Reply: Ignition key tumbler problem
