brake bleed
Old 01-15-2012, 01:14 PM
keith G's Avatar
Default brake bleed
overheated the brakes on the E350 winnebago,put new rotors and calipers on,but the pedal is no where near as good as it was,bled them 5 times,is there a special way of doing ABS brakes?
is there a bleed screw on the servo or something else i've missed........
cheers..........keith
Old 01-16-2012, 11:35 AM
bluewind's Avatar
According to the Haynes manual in the Ford Windstar you let gravity flow the fluid for 5 minutes. Then you to the pump method with at least 25 cycles per wheel. If that does not give satisfying results take it to a shop that uses a diagnostics computer.
Looks like some one gets to exercise a leg today...
Old 01-16-2012, 01:44 PM
keith G's Avatar
looks like the Mrs is gonna have thighs like a russian shot putter then!!!!......
crazy96863
02-08-2013 09:44 AM
dave boley
10-29-2012 11:45 AM
MercuryMountaineer02
07-07-2011 08:45 PM
brian_ensminger
04-10-2011 09:08 PM
ryanjantz
09-08-2006 12:17 AM
Quick Reply: brake bleed
