Change window motor
Change window motor
85 Econoline......Unhook battery. Tape window to the frame with packing tape. Remove armrest and door panel. Drill the heads off 4 rivets near the center of the door. Punch out the pins from the rivets. The regulator and motor will drop. Spin the regulator and motor to the left and take it to the bottom of the door. Unhook the power cable. The regulator and motor will now come out the bottom of the door. Change the motor. Make sure that it is in the same position on the regulator that the other one was. Reverse to reinstall. The hardest part will be getting the regulator arm into the slide on the window. slide a bolt into the regulator when you get the holes lined up. Use a clamp or vise grips to hold it tight against the door frame. You will need to rivet it back to the door. There is no access to the back of two of the four holes.
I changed both sides today, it took about 6 hours. On the off brand motors(Dorman is what I bought) only two of the three holes in the motors will line up.
This is not an easy DIY job, but it can be done.
maybe next year.
Rusty I think you hit a nerve with your question.
A good part of the time certain parts are no longer available from the dealer.
After you get burned enough times you do everything you can to stick with OEM parts.
They cost more, but there's nothing like doing the job over.
If I go to purchase a part and it's made in chow mien land I have learned to just give it back and go somewhere else. The sore spot on the nerve is a lot of aftermarket companies spend a lot of $$ promoting their junk where they could improve the quality with that $$. It's cheaper, but it usually doesn't last as long as OEM and many times it is defective right out of the box. Hopefully , some of our "manufacturers" will consider making the parts back here in the USA where quality was a given. Many dealer parts are made out of the country, but I think they have higher standards than most imported junk.
