E350 rear heater connections
this is my first day on the forum. can't find any info on leaking coolant lines for the rear heater in my 1996 E350. seems there are 3 coolant lines whenI expected 2. any guidance would be respected and appreciated
Which engine do you have? Normally, there should be 4 lines going back to the AUX A/C-Heater system (Coolant In-Out and A/C Hi-Lo Pressure) unless Ford used a COMBO line for the A/C (like they did on the Windstar/Freestar vans). Then you would only have 3 lines until the A/C line got to the back, then it would split back out from a "Y" block.
The smaller line would be the liquid line to the rear A/C evaporator. The large line right next to the small line should be the suction line from the rear A/C evaporator. The other 2 large lines would be the coolant lines. The easiest way to verify this would be to fire up the engine and turn on the rear A/C unit. With the A/C compressor running, the small liquid line should get hot and the suction line should get cold. Or, you can leave the A/C off and let the coolant get up to operating temp. The coolant lines would then be the 2 lines that get hot.
