fuse box
Old 10-25-2015, 11:23 AM
joey7478's Avatar
Default fuse box
Why can't I find a fuse box diagram for my 1990 E150? What all does the computer run or control? Thans joey!
Old 10-26-2015, 01:52 PM
joey7478's Avatar
Default fuel pumps
Will the fuel pumps run if out of gas?
Old 10-26-2015, 03:08 PM
As you know the fuel pump runs for 2 seconds when you first turn the key on. If the computer does not see an engine RPM signal from the dist. it will not allow the fuel pump(s) to run.
Soooo, if the engine can't run because it is out of gas , the fuel pump won't run either, but if you have fuel and you keep cranking the engine it will produce an RPM signal and the pump will run and flood the engine if for some reason it does not start.
Old 10-27-2015, 09:02 AM
joey7478's Avatar
Thanks hanky Joey!
bettabegood33
03-05-2019 05:30 PM
stptak
04-14-2013 02:48 PM
94tbird
08-07-2006 02:53 AM
AndrewMacks4.0
07-13-2006 12:44 PM
biebrich73
06-30-2005 12:52 AM
Quick Reply: fuse box
