Ignition Problem
Old 03-26-2013, 05:09 PM
ShaGater's Avatar
Default Ignition Problem
I have a 1990 Econoline 150 and the ignition has been hard to start for a few months now. Yesterday when i went to start it i had my boyfriend do it because i couldn't and now the whole key just spins in the ignition without any resistance and I'm pretty much stuck. Trying to find out the problem over the phone doesn't seem to be working with the local mechanics so if anyone has an idea about what it is I'd be grateful. Couldn't i just get a whole new ignition system installed?
Old 03-26-2013, 09:46 PM
go-part's Avatar
Former Sponsor
Sounds like your ignition switch needs to be replaced
Signs of a Bad Ignition Switch | eHow.com
Old 03-27-2013, 03:36 PM
There are two possibilities.
The first one can be easily corrected by replacing the ignition key tumbler section where you insert the key.
The other possibility could be the link down to the switch assy mounted on the steering column maybe disconnected for some reason. Usually if the tumbler section is good you can't rotate the key as you state. So I would think you could solve the problem by just changing the tumbler assy, Not that difficult to do.
krazydawg40
03-28-2007 04:58 PM
SleeperFan
02-09-2007 01:05 PM
bighueyy2k2
10-12-2006 10:58 PM
riska720
10-26-2005 04:20 PM
highpowerd2003
08-29-2005 10:56 PM
Quick Reply: Ignition Problem
