Newbie! Help? Patching holes in flooring
Old 04-23-2015, 10:39 AM
RedSled's Avatar
Default Newbie! Help? Patching holes in flooring
Greetings Ford Forum members. I found the van of my dreams and I love her! She is a 1998 E350 cargo van with the 7.3l diesel engine with only 89k miles. She is a one owner who took really good care of her. It appears she has been in storage since 2009 from the dates on her tires. So far I have removed dividers, cabinets and yucky rubber mats. The plywood flooring is out and we are at the bare floor. We cleaned her up with Simple Green and are ready to insulate and begin the flooring process. I have a question about the holes in the metal from the cabinets. To patch the holes, someone suggested to use adhesive caulk and fiberglass cloth. Then use a flexible rubber liner coating. After that we can begin to insulate with acoustic sound barrier. Re install the plywood. Then an underlayment on top of the plywood, then float cork flooring. Any comments, ideas, suggestions, photographs, etc. would be greatly appreciated. Thank you!
Old 04-23-2015, 02:19 PM
Hi RedSled,
You will probably get several suggestions to help with your question. I would suggest that you consider filling the holes with bolts ,nuts and washers ,then coating them, both inside and underneath the floor because you may keep the inside clean and dry , but moisture will still get at the underneath metal and if not covered with a protective coat of something the holes will leave bare metal to the elements. You found a good vehicle there and it should serve you well. Send some pix when ready !
RedSled
04-23-2015 11:20 AM
RedSled
04-23-2015 10:41 AM
Virg54
12-08-2012 09:04 PM
jtpilot1
03-20-2010 08:37 PM
tnvolno1
07-23-2006 07:15 PM
Quick Reply: Newbie! Help? Patching holes in flooring
