No Spark
Don't fret, the wire from the capacitor is supposed to connect to the ign source coming from the switch. It is there to protect the switch contacts and for radio noise suppression.
Just a suggestion,
when cranking do you get spark coming out of the coil hi tension wire that goes to the center of the dist cap?
If yes, problem with cap/rotor
If no,let us know. OK with you Grindman?
Just a suggestion,
There is a lot that has been done on this particular vehicle. The injector/TPS/ and sensor wire harness has been re-made after being melted in a fire. Worked good after I remade it. ..Put about 2k miles on it.I had 3 wires that weren't connected during this time. 2 I knew went to the Idle Air Bypass solenoid. The last had no clue. Mixed them up. Fried the Mystery wire which I traced back directly to the ECU (pin 52). Needless to say it went to ****. It even ran with the bad computer. Ran like crap and wouldn't shift gears but it ran. I have replaced the ECU.
I went back through the entire harness. (I finally got a better diagram) found only 1 mistake. but like I said it was ready running.
But today's issue is puzzling. Unless my rotor just decided to no longer make contact with the cap is weird.
You have my sympathy for the burned wire problems. Like that's a lot of help !
Anyway, we need to know if you are getting any output out of that coil right now when you crank over the engine.
Pull that hi tension wire out of the center tower of the cap place it about a 1/4 inch from any metal part of the engine-ground and have someone crank the engine over so you can see if spark is jumping from the end of that wire to ground. Either you will have spark or you will not. Depending on what you get will determine your next move.
