Pinion shaft lockpin 5/16 in., removal.....
Old 08-17-2016, 02:25 PM
Polly's Avatar
Default Pinion shaft lockpin 5/16 in., removal.....
My van is a 2001 E150, and I am trying to do a rear wheel bearing and seal replacement job. I got a new lockpin (with loctite on it) from my local Ford dealer, but I am having trouble getting the old one out. I've got a 5/16 th socket (6 point) with a 1/4 in stub plugged into it, and a 1/4 in box wrench around the stub. It feels pretty good when I fit it onto the bolt head, but the bolt won't move, even with some hammer taps, and the head is starting to round over. Any suggestions would be appreciated.
Thanks.
Old 08-18-2016, 09:25 AM
Thumbs up
Tried a little heat yet?
Heat and some stiff hammer taps to the head of the pin, it should break loose.
Old 08-18-2016, 10:21 AM
Depending on what source of heat you choose to use , you might want to keep a fire extinguisher handy !
Old 08-19-2016, 11:40 AM
Polly's Avatar
I will try some heat, probably with a heat gun. Using a torch under there is too scary for me. I also found that there are screw removal tools specifically for this application, because so many of these lockpins shear off when removed.
Thanks guys!
clarence
10-15-2010 03:30 PM
jobi
10-21-2007 10:51 AM
demomatt
04-24-2007 01:13 AM
jparker82484
07-21-2005 04:11 AM
ODB
05-11-2004 02:45 PM
Quick Reply: Pinion shaft lockpin 5/16 in., removal.....
