shifting problem
shifting problem
ok I have a 1994 e150 5.8 don't know what transmission it has anyway when the van is cold the trans wont shift I can manualy shift from o/d to 2nd then it shifts, but after I drive it for awhile and it gets warmed up it will start to shift any one have an idea whats wrong.thanks for any help
i'll be damned did some research found out it could be a tps related problem so I pulled the throttle body replaced the tps and that van is shifting like a dream who woulda thought,well if it don't rain tomorrow im going to service the trans
Depends on how determined you are.
There is a lock ring that breaks for the OD and the valve body needs to be removed from the trans to find and get the pieces. Are you able to handle something like this? You also have to be able to get the OD band in the correct location for the OD servo piston to make it work correctly then install the piston and retaining ring. Not a difficult job , but can get difficult if pieces are not assembled correctly.
