2007 Ford Edge Mystery Problem
Old 05-10-2014, 10:01 PM
MJP00's Avatar
Default 2007 Ford Edge Mystery Problem
At a loss here.. 2007 Ford Edge 110000 miles on it and have been having a problem for the past 2 years I would say. Never thrown a code or died on me but for the life of me and my mechanics cannot determine the issue. While driving down the road at any speed limit and holding speed my Edge begins to "sputter" and "buck" wildly until I give it a little gas and it stops. This issue is extremely bad on the highway even with cruise on. When accelerating just slightly and passing someone it begins to violently sputter forcing me to give it even more gas. I am at a loss, the only thing I could even imagine is a stopped up fuel filter but it is a lifetime filter according to Ford. I have ran cleaners and cleaned the MAF sensor and had it looked at with no luck but I have found others online with similar issues but no solution.. Please help
Old 10-25-2014, 12:26 AM
00_WINDBAG's Avatar
Dont know of you figured out the issue seeing as you posted this back in May but I would plug in a scanner and check for cylinder misfire counts. Codes wont appear unless you have a certain number of counts. This may lead you to the problem cylinder.
Old 08-18-2017, 11:19 PM
Mateeto's Avatar
Default Update?
What did the problem end up being? Thanks!!
Jon Nisbett
02-22-2022 07:48 AM
Jon Nisbett
10-22-2013 01:45 PM
Jon Nisbett
10-21-2013 04:00 PM
badedge
05-14-2012 03:27 PM
rojaspga
12-02-2011 01:46 PM
Quick Reply: 2007 Ford Edge Mystery Problem
