2015 Edge transmission check
Old 12-11-2015, 04:43 PM
edge150's Avatar
Question 2015 Edge transmission check
Does anyone have a method for checking the transmission fluid on a 2015 edge awd with the 3.5. the owners manual is no help
Old 12-11-2015, 07:19 PM
There is a reason you are asking , can we ask why? Some newer transmissions have no provision to add nor change the internal filter. When they quit, replace trans !
Old 12-11-2015, 08:36 PM
edge150's Avatar
Default tran check
I am the one waiting for the dealer to get the tools around to fix the leaky seal. I haven't been driving it but wanted to see what the level was the dipstick is down below some air cleaner thing and it can't be done like it says in the owners manual. There is a picture in my profile of the leak...it is in about the middle of the car but I can't get a good look at how things are put together under there with all the plastic shields and the close clearances. If that shaft is coming from the PTU the fluid in it must be contaminated with ATF.
15mustang
05-20-2016 12:31 PM
dixieoutdoors
10-05-2015 04:14 PM
15mustang
02-08-2015 07:15 PM
Drubush
10-13-2014 02:37 AM
wdr15904
07-16-2013 02:21 PM
Quick Reply: 2015 Edge transmission check
