Gearshift indicator light? - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 11-04-2012, 01:48 PM
Default Gearshift indicator light?
2010 Edge. There's an indicator panel next to the floor shifter. As most, it indicated P,R,N,D,L. However, at night this panel can't be seen without turning on the map light. Is there a light bulb under there that's burned out, or is it just not lit.
Old 11-04-2012, 02:53 PM
You may need to remove the covering to determine if there is a bulb under there or if they use a piece of fiber optic cable to transmit the light there. If so follow the fiber cable to the light bulb source and replace the bulb.
Old 11-08-2013, 05:07 PM
On a 2010 ford edge, how to replace a burnt out gear shifter light bulb and remove the cover.
Thread Thread Starter Forum Replies Last Post
04 exp gearshift lever hard to shift into park pats99ranger Ford Explorer 0 11-19-2009 07:25 PM
02zx2 gearshift locked in park kleiney Ford Forum Help & Suggestion Center 3 01-06-2008 03:10 PM
2003 SES int brake light indicator shawnpd Ford Taurus 1 11-03-2006 12:23 AM
Ford Ranger battery indicator light UPDATE pterns Ford Ranger 1 11-14-2005 12:57 PM
Ranger battery light indicator pterns Ford Ranger 1 11-04-2005 09:32 PM
Tags
2012, bulb, change, edge, focus, ford, gear, gearshift, indicator, lamp, light, panel, replace, shift, shifter
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
