04 escape transmission problem
Old 10-23-2016, 02:56 AM
That converter problem may not apply to the trans in your vehicle. A pressure check would still help confirm if pressure loss is the problem.
  #12
Old 10-23-2016, 09:23 AM
thomasjkt's Avatar
I am getting Input out speed sensor faults on the code reader now
  #13
Old 10-23-2016, 04:38 PM
We "almost always" try to do the easy things first, that's why I suggested to confirm that the trans was delivering pressure when it warmed up and wouldn't move. It never hurts to check the electrical connections at the trans for corrosion or faulty connections. If you try all the easy checks first and they are OK, then you may need to get into more detailed work.
farsee
05-18-2015 11:25 AM
UncleGiggles
06-04-2012 05:17 PM
trev0006
04-10-2012 09:31 PM
escaping
11-22-2010 08:44 PM
digbmx4130
10-21-2010 04:14 PM
Quick Reply: 04 escape transmission problem
