RE: 05 ESCAPE GAS PEDAL STICKING
You need to have the throttle body cleaned. This is usually done when the injectors are serviced or the intake is serviced. If you haven't had either done, then you can clean the bore of the throttle body with a combustion chamber cleaner. Spray it into the bore and let it set about 15-20 mintues and then start the vehicle and continue to spray around the outside of the bore where the butterfly plate seats. Also have the pvc valve changed as it contributes to the build up.
__________________
Too Old to Work, Too Young to Die.......GO fishin'
35 Years with Ford
ASE Master
Ford Engine Master
L1
