2012 AWD Escape Rear Wheel Bearing
Just looking to see if anyone has done this before. Never done a rear wheel bearing with drum brakes before. Always been the front end with disc brakes. Is the rear bearing pressed into the drum backing plate? If so to remove that is it just the 4 bolts in the back of the plate that need to be removed to pull that off? I have a press readily available to be able to press the old one out and the new one in. Thanks
makuloco2000
11-09-2014 11:44 PM
