2015 Escape SE Light, Turns and Wiper Problems !!!
Hi, I got Ford Escape SE 2015 with front end collision. I had to replace some front parts, and after all was fixed now I have issues that:
1. My Wipers dont work properly, they get into collision and get stuck;
2. My Left low/high beat light dont work properly - when on low beam, the bulb is very dark compare to the right side, and when I turn on high beam, the left side goes away completely.
3. The turn signals sometimes work OK, sometimes click quicker than suppose to be, like on the bulbs is Out, when its Not.
Also, my car, doesn't speed up as suppose to. It has 2.0 Eco engine, but it is soooo slow when I drive it.
ANY ADVICE ????????????
I don't know about advice, but you might want to check that all the ground wires are connected for the left front of the vehicle and for that matter the ground wires that ground the sheet metal and body to the battery negative post. From what you describe it sounds like one or more are either not making a good connection or may be missing entirely.
kalenkerby
03-27-2014 03:58 PM
tcrate
09-09-2011 07:11 PM
