Doing front brakes 2010 Escape.
For anyone that is wanting to know, I did the front disk brakes on my 2010 Escape, and it was super easy. All you need is some brake fluid and a # 7 hex key attachment for your socket wrench. There are some good videos on you tube.
Also need a " C" clamp to push in the piston on the brake, so that you can get the new pads in. Good luck.
I replaced the pads only. I bled the brakes because it replaces the old fluid with new fluid in the lines. My dad always says this is best, and it is only a little extra work.
