Escape Horn Wiring
Old 02-03-2008, 10:12 PM
armydoc's Avatar
Default Escape Horn Wiring
I am trying to wire a 2008 Escape for a Fire Department Response Car and I cannot locate the horn and horn ring leads (wires) under the dash leading from the steering column or under the driver's side dash to the horn assembly. None of the Chilton Wiring Diagrams I have show the horn and horn ring wires on them. Does anyone know where the wires are located under the dash and what color the horn and horn ring wires are??? Thanks,
CPT J. Hurt
Old 02-04-2008, 09:42 AM
Default RE: Escape Horn Wiring
First let me say, be very careful about tapping into wires on this vehicle as it has air bags. There is no horn ring, the horn switch sends a signal thru the clockspring to the horn relay, the relay is what energizes the horn. Not sure what you are tapping into, do you need to power the horn, or what? The wire color to the horn itself is yellow/red. The input from the switch to the horn relay is brown.
Any wire loom you find wrapped in yellow, is for the air bag system and should not be tampered with.
dbabber
01-07-2009 07:03 PM
coreysm2001
05-31-2008 09:33 PM
shoebooty
04-26-2008 11:29 PM
heini62
10-23-2007 07:31 PM
jakec8
12-03-2005 02:26 PM
Quick Reply: Escape Horn Wiring
