Escape ABS disable
Old 08-18-2008, 03:57 PM
myjeep's Avatar
Default Escape ABS disable
Can you disable the ABS system on a 2003 ford escape?
Old 08-20-2008, 05:31 AM
Default RE: Escape ABS disable
yes i think it can, you can take to the dealer. but why you want to disable Antilock Braking System? what is your reason? this is good feature.
Old 08-21-2008, 07:01 PM
myjeep's Avatar
i dont want to change the axil, the ABS system is comming on all the time and the fix is $700
Old 08-22-2008, 07:54 AM
do you mean ABS light system is comming on all the time?
Old 09-03-2008, 06:11 PM
myjeep's Avatar
no i mean that the ABS system is comming on all the time.
Old 09-08-2008, 02:54 PM
I am assuming that you have been told that you need a tone ring, which requires you to get a new axle halve, Thanks to this site I found out that I too had the same problem, I confirmed this on Sunday by taking the tire off and rotor and found that is is indeed broken,
1st I would like to say thanks to all you guys for having this site and posting on it.
Now Ihave an appointment on Wednesday to get the front passenger tone ring replaced, I have an 2002 escape, and the dealer told that even though Ford says to change the axle, you can buy the rear ring and they can press it on you existing axle, so instead of a $700 cdn fix, he has quoted me $225.00, so we'll see and I will post my outcome.
Now if you want to disable the ABS, just remove the fuse.
I will also post pics tonight of what a tone ring looks like and you can see where mine was broken.
Thanks Again guys
[IMG]local://upfiles/17815/85997F3A82E44BF5B22CAA8A55A1D13E.jpg[/IMG]
Old 09-11-2008, 07:50 AM
Worked out fine, done by the dealer for $201.45 cdn.
Old 09-15-2008, 08:30 PM
Why can't you just tack weld the tone ring to the piece it sits next to and call it good? Both pieces rotate around together and it would keep the tone ring from slipping out of place.
Old 09-16-2008, 06:53 AM
you can't do that unless, you are a very good carver and can get the same profile, as it runs through the abs sensor, and besides that seems to be a hillbilly mickey mouse way to fix your brakes.
you know those things you need to stop your car with.
@skiinmitch
02-07-2012 04:32 PM
warpwr
03-16-2008 10:00 PM
vizslamichel
10-26-2006 11:18 PM
tampabulldog
03-14-2006 04:50 AM
PowerBBS
06-15-2005 03:00 AM
Quick Reply: Escape ABS disable
