1999 XR2 A-Transmission will not shift
I have a used 1999 ZR2 with a transmission issue (71K). I have a used "tested" replacement transmission but before I replaced I wanted to see if there were any other things I should check first. The engine runs great and the transmission smoothly shifts from drive to reverse. Issue is that it will not move out of low (max speed ~25 mph). Any thoughts of possible things to look at prior to replacement?
petehack
11-10-2014 05:20 PM
trev0006
06-05-2013 11:50 AM
austincachia
09-16-2006 10:06 AM
