98 zx2 CV axles
98 zx2 CV axles
I'm changing out my CV axles on my 98 2.0 manual. I've finished with the driver side,but I cannot get the passenger side out of the carrier. I'm working on the ground and I have it removed from the hub. Are there any tips or tricks or tool that I can use to remove it? Help please
the passenger side simply slides out of the transmission. Before this happens there are 3 bolts which need to be removed from the engine. Follow the axle intermediate shaft to the point on the engine near the oil filter. There you will see a bearing holding the intermediate shaft to the cv axle. At this connector there are the 3 bolts you will need to remove. Once removed the axle will be able to be removed without any further issues
Troy78
08-01-2010 01:34 PM
speedy431
11-20-2006 02:36 PM
