1988 GL Hatchback, sat for 10 years
Old 08-15-2013, 07:47 AM
l.o. guvna's Avatar
Default 1988 GL Hatchback, sat for 10 years
Hello members,
I am new to FF, joined about a month ago. I inherited this 88, and I'm sure it has sat, covered, for 10 years. Battery is dead, the gas smells like varnish. I believe this to be a carb'd car, although the data that I find shows this model with some sort of FI. I've towed it to Texas from NC last weekend. The brakes seem ok, and the tires are so so. Car has 79K on it.
I'll spend some time getting it running, but want to know where I can find vendors for mechanical and cosmetic. I expect to replace the common areas, and probably AC components too.
Any advice on these areas are appreciated.
cheers
Old 08-18-2013, 10:19 AM
l.o. guvna's Avatar
well, with no replies, I can at least update the project.
car is at the mechanics, and we put a new battery in - decided to just try to start it even with the varnish smelling gas. no sounds from the electric fuel pump on the tank, but it would run with some b12 spray to the throttle body. yes, this is an EFI car. it actually sounded fine when it was running, so i believe the motor is good.
i have ordered a fuel pump, strainer, and new injector - from partsgeek.com, btw. they seem to have alot of parts for this car. i'll update on the project after this next round of work.
LO Guvna
active contributor to 6-pack.org, a TR6 site
Old 08-18-2013, 09:29 PM
bluewind's Avatar
Most parts stores will be able to get you the basic pieces you need. Make sure you use quality products for everything.
RockAuto.com can save you a few bucks, but again stay with quality.
Wagner Brakes
Motorcraft, borg warner, for ignition
Monroe for struts
O'reilly's sells good quality remanufactured alternators if you need one.
You probably need a timing belt: Gates
hopefully you drained the old gas. At least be ready to change the filter a few times.
Expect all manner of rubber parts to fail due to age.
Watch some youtubes on how to do various tasks if they are new to you.
Please keep us posted!
Old 08-19-2013, 01:45 PM
l.o. guvna's Avatar
Blue,
great advice, and thank you for the time in sharing. i have some 1st stage parts on order, and will get around to the basics you mentioned above. I don't like running this motor on an old timing belt, so that is next once running, along with a tune up, and fluid changes.
i started looking a brakes, and one of the tricks we did with our triumph group was uprate the rear wheel cylinders. i can get stock toyota 4 runner calipers, 4 piston, lifetime warranty for my 6 for 30 dollars apiece, so thats a nice cheap upgrade for our old cars. and with rear wheel cylinders, we can increase the bore and improve the stopping power. the 83 escort has a 7/8 bore, compared to our stock 13/16 bore, and for about 8 dollars a piece. 8 dollar for left, 10 dollar for right? only change in the image is the bleed screw is in the other hole. tempted to buy 2 8 dollar cylinders, and swap the bleed valve.
sorry for the ramble. In the meantime, the parts are in route - and will update this thread as the car goes to next steps. can we post pics? probably. I'll get those going on the next input.
cheers
LOG
Dallas
Old 08-19-2013, 03:04 PM
bluewind's Avatar
Yes, you can cut and paste pix.
This proofs it. Do you know what kind Ford this is?
Old 08-19-2013, 03:59 PM
l.o. guvna's Avatar
proves, you mean?
well, if I had to guess at this model, I'd say its a 61 ford obscure.
cheers
Old 08-20-2013, 04:53 PM
bluewind's Avatar
you know your Ford models! LOL
In fact it is the '62 Ford Taunus of Ford West Germany.
Originally designed here in the states, with FWD and a V4 engine. It was intended to stem the flood of imported VW beetles. But management got cold feet thinking it was too modern for the American customers. This was almost my first car.
Spelling...I must have had some booze on my mind! (80% proof?)
Old 08-20-2013, 08:50 PM
l.o. guvna's Avatar
Blue,
You and I are going to get along just fine. I was close on the year! Save a glass or pint for me at the next car meeting...
That is awesome - learning stuff like that. I am very happy to be here, even if it is with my sad escort. such a heritage. I am a fan, please don't think my comments were insulting.
and to all those reading, thanks for at least peeking in. I am excited about this project, as my tr6 project is stable, this gives me something to focus on for 2 years as my daughter gets ready for her license.
cheap parts, moderately reliable, underpowered, and unsexy to boyfriends.
cheers -
LOG
Old 08-21-2013, 03:34 PM
bluewind's Avatar
TR 6 and Escort?
Scotch or Rye?
(Honestly, I don't do hard liquor. A glass of Cabernet Sauvignon or an occasional beer, Sam Adams Boston Lager, is all I care about.)
Old 08-22-2013, 09:12 AM
l.o. guvna's Avatar
no whiskey for me either - a pint or a glass of some red wine.
have a great weekend. my partsgeek parts are in - i'll try to get this thing running, and look for leaks.
cheers
Jrocker
11-30-2013 01:51 AM
Bambam456
04-16-2013 09:40 AM
explodegirl
07-01-2008 11:12 AM
TBoonsboro2
01-15-2006 02:13 AM
cacahuate_01
01-06-2006 07:25 PM
Quick Reply: 1988 GL Hatchback, sat for 10 years
