Rear brake drums
Old 04-22-2014, 11:01 PM
twj815's Avatar
Default Rear brake drums
I need to replace a bad wheel cylinder on my '98 ZX2. My Haynes manual talks about using some bolts to push the drum off of the hub. What size and length bolts should I get?
Old 04-23-2014, 08:45 AM
I do not remember the size bolts to use, but your main concern will be to be able to back off the self adjuster if you have to, in order to remove the drum. Unless the drum is rusted to the hub a few clunks with a hammer will usually break the drum loose from the hub. You may not need the bolts to remove the drum . Many times prying evenly on two sides will get the drum off
cesarhernandez74
07-29-2014 02:05 PM
LILRANGER
08-02-2013 09:05 PM
blackharley
08-21-2008 11:04 PM
tnfritch
01-25-2007 08:36 AM
Dakota_Don
03-27-2006 08:57 PM
Quick Reply: Rear brake drums
