rough idle stops when climate control tuned off on dash
Our 1999 Escort SE idles up and down at stop lights but if we turn the climate control dial to off on the dash ( meaning no heat or no AC ) the idle is normal. Return the climate control dial to any heat setting: defrost, vent, floor etc and the engine idles up and down, sometimes almost stalling. The AC works fine. At highway speeds all seems normal. Is this a case of the WAS relay in the CCRM engaging the compressor at the wrong time ? It sounds like the compressor is coming on when the idle drops.
