Jump Start
Jump Start
I jump started another vehicle then got in, and my Diesel Excursion was running, but gauges didnt work and it would not accelerate. I shut it off, it restarted still no gauges or acceleration. I turned it off again, and it wouldnt start I think because it ran out of fuel, because fuel pump was not running. Any one have any idea?
RE: Jump Start
I'm at work right now and can not look at my 01, but check to see if there is a fusable link connected to the positive side of the battery. This sounds like a possibility since you have no electrical functions other than starting the diesel. I would think that if you had a gasoline engine that it probably would not restart since there would probably not be anything to fire the sparkplugs. Hope this helps.
RE: Jump Start
When connecting jumper cables on any newer vehicle ALWAYS use your owners manual so as not to fry the electrical system. Check fuses/fusible links first. Then look for overloaded circuits in any blown fuse/link wiring.
