2000 Expedition Trans Question - Ford Forum - Enthusiast Forums for Ford Owners
LinkBack Thread Tools Search this Thread
Old 07-15-2010, 03:11 PM
Default 2000 Expedition Trans Question
I have a 2000 Expedition, Codes are as follows: P0743, P0755, P1747, P0443, P1451, P0135, P0155, P1409, P0141, P0161.
When put in gear motor starts to miss very bad. When put in 1st truck will move but still misses very bad
163,000 miles
Any help would be apprecitive.
Wayne
Old 07-15-2010, 08:27 PM
In trying to decipher those codes, many relate to the oxygen sensor heater circuit. Check all the fuses first. From what I was able to conclude most if not all your codes are from an electrical failure supplying several systems.
For now I would start with all the fuses and replace any that are bad and see what you uncover. hanky
Old 07-18-2010, 10:31 AM
Default Fuse
I found fuse number 23 under the food blown, I replaced the fuse and everything seems normal. The fuse description is HEGO Sensors,Canister Vent, Automatic Transmission, CMS Sensor
Any Idea what may have blown the fuse?
Old 07-18-2010, 06:54 PM
If it doesn't reoccurr, I wouldn't worry about it. If it does blow the fuse again, there apparently is an intermittent problem. It could involve any of the circuits the fuse protects. Lets see what happens before we get overly concerned OK. ,,,,,,,,,,, hanky
Old 07-18-2010, 08:55 PM
Default Thanks
Thanks hanky, The truck is new to me, the only thing I have a concern with is the shift from first to second is abroupt if I'm on the gas. If I baby the gas its fine. Could this be the problem? would this be the first shift module is this hard to change?
Thanks again
Wayne
Old 07-18-2010, 10:06 PM
At this point I don't think so. Trying to do this right we need to do some more checking. Sometimes, when you have corrected a problem the computers need time to adjust to a new shift schedule. Drive the vehicle normally for a while and see if the problem lessens or goes away completely OK? Patience pays. ,,,,,,,hanky
Old 09-01-2010, 03:29 PM
Quote:
I
163,000 miles
Wayne
I have the same problem with my 02. Did you find the problem?
Janelle
Old 09-02-2010, 07:36 PM
Quote:
Janelle
Fuse number 23 under the hood
Good luck!
Thread Thread Starter Forum Replies Last Post
For Sale 72 - 460 motor & trans - For sale 60's 430 motor & trans conanalois PRIVATE For Sale / Trade Classifieds 0 08-31-2013 07:16 AM
trans question joemar6988 Ford F-150 0 03-29-2008 11:32 PM
trans question anjm2004 General Tech 0 07-28-2007 04:34 PM
Engine/Trans Swap Question Hockey Stud Ford F-250 & Ford F-350 2 05-03-2007 10:49 PM
'96 Contour automatic trans question Sanguinius General Tech 0 12-22-2005 05:49 AM
Tags
02, 2000, automatic, canister, cms, expedition, ford, fuse, hego, o2, senor, sensor, sensors, transmission, vent
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
